Results 1 to 2 of 2
Thread: How to test fuel temp sensor
    Jun 2009
    South Texas 1 mile from border and ocean
    Default How to test fuel temp sensor
    If someone could tell me how to test the fuel temp sensor i have a volt meter. MY 95 Disco will not start when at normal operating temp. Spark at plugs good, no smell of fuel in exhaust, eng oil is clean no fuel in it, wires, spark plugs air filter, good. On a cold start the eng runs perfect, drives perfect untill it turned off and restarted.
    Feb 2009
    Ohm it out with heat... if ohms change it is good.
    reading your other post I would say possible fuel pump, when it is hot it is not happy.
    97 Disco
    10 MCCSm
    Custom Rover Accessories
    Home of the D2 horn buttons
