Results 1 to 3 of 3
Thread: Disco II abs/traction control
    Jan 2007
    NH
    8
    Thumbs up Disco II abs/traction control
    My wife drives our disco II. "2000" The abs and TC goes on frequently, when it is not needed. The brakes were just done. The temp gauge sensor goes off and on at this time also! Does anyone have this issue?/ or a solution? Regards Jeff
    Fairbanks Alaska
    24
    Default wheel speed sensor?
    It may be a wheel speed sensor. Could have been damaged or dislodged on one of the wheels when they re-did your brakes.
    Jan 2007
    NH
    8
    Default abs/ traction control disco II
    There was a wire that was frayed in the harness of the abs. The abs sensor was also bad. Regards Jeff
