Results 1 to 3 of 3
Thread: P38 overheating
    Default P38 overheating
    As of tomorrow, I will be the proud (I hope) owner of what seems to be a very well maintained 1999 4.0 P38. It appears to be in great shape. No rust, no dents, new tires, yada yada... But I am told that it overheats from time to time. Ran fine for the 15 minutes that I test drove it. Owner says that sometimes, it just overheats. Could the answer be as simple as replacing the thermastat? Can you just remove the thermastat and run these trucks or does that create some other issue? (We are in Florida so it is not an uncommon solution with other vehicles.)
    Feb 2009
    Cincinnati
    130
    On a Rover you will need the T-stat... I am not sure I would buy a Rover that has a history of overheating, you don't know how long it overheated or how far it was driven. You could be looking at something as cheap as it need a new T-stat and radiator flush to buying a new engine very soon.
    All Aluminum Engines do not like to be overheated.
    Joey
    97 Disco
    10 MCCSm
    Custom Rover Accessories
    Home of the D2 horn buttons
    Oct 2009
    South Jersey, The Pine Barrens
    155
    If your coolant level is low, when you turn a sweeping corner the guage may FLY to hot.....Panic ensues...but just let it cool and then check your coolant level. Many times a litttle leak at the heater O rings will run the coolant level down.
