91 rr idles around 3000rpm
My 91 rr has sat for for about a year. I needed to use the rr and started it up, which happened right off the bat. The problem is it idles at around 3000rpm. The linkage does not appear to be stuck, vacuume does not appear to be pulling on the linkage either. Is there an electrical sensor I need to be looking for? I need to get it to idle correctly so I can pass inspection. Thanks for the help!
I want to sell this rr as well. 130,000 miles only. Interior sucks, good leather, body has one small depression on right rear, strong motor and gear train. No ac and has always passed inspection. This rr is in the houston area. I will let it go for 1500, obo.
Jeff
