kinda odd. here are the symptoms...
110 nas v8
engine dies. no rumblin' bumblin' or stumblin'.
sometimes, the rpm at idle drops to 250-400 and its powerless, but running. like a bank of cylinders is out. i was on the highway when that happened, and i cut the ignition and it restarted while drifting. but mostly i have to wait 2-3 minutes and it will restart.
check engine light comes on, but there are not any error codes... mostly. twice i got a code 03... there isnt an 03.
it did this about 4 months ago then stopped. i just changed the cap and wires and it did it 5 times.
bit of a bitch changing gears going around a bend in traffic and you lose the power steering and you almost get reared.
