Originally Posted by
CliftonRover
I would say first put chains on the back and if you feel that you need it put them on the front. when chains are on the front they can get caught and rip up a lot of stuff if the chains come loose.
I respectfully disagree. Chain up the fronts first, then if needed, put a pair on the rears also. If you only chain up the rears, you'll get understeer.
CliftonRover is right on about clearance- make sure your chains fit correctly so they don't damage your vehicle. The best way to do this is test- fit before you really need them. Once you have chains installed, drive a short ways, then tighten. Repeat as necessary.
Good luck!
Paul.
'08 LR3
'04 Mini Cooper S
