I also think the OD is the cause of the problem. If that is the case the part can be replaced and you are going again. That would be my first check. Just hope the rest of the OD is OK if the drive gear is the problem.
Jim
Jim
Did one last bit of diagnosis work before leaving town - applied the parking brake - same whhhrrrr sound, clutch out did not stall.
Just move all the damn levers until something happens. I'd bet on the t-case lever.
So, the rover may move again sooner than expected...
Santa brough me a warn winch
more on that anyother time
Could be a broken overdrive. You can replace it with the stock gear & back plate to check. I'd go there first since you have already played with the levers. There's a reason why people with overdrives tend to keep all the old non overdrive parts in the truck so the OD can be removed away from home.
Layshafts commonly break and when they do it feels & sounds about the same as a rear axle snapping. When mine broke I still had fourth gear, which is lucky because I was at the California Oregon border and a long way from home. Fourth was the only gear I had.
Mostly the sound is associated with an axle breaking, transfercase popping out of gear, overdrive breaking or a gearbox shaft breaking.
Good luck & hopefully it is something easy & cheap to repair.
Teriann Wakeman_________
Flagstaff, AZ.
My Land Rover web site
I agree, the two times I have broken a layshaft I always had some gear left, usually 4th. Fun driving home using low 4th and hi 4 only!
1963 Unimog Radio box
1995 LWB RR
We had an unexpected break in the weather this weekend so I got a chance to dig into the rover's issues for the first time since it died on me.
I've learned one thing, I still have no clue what I am doing
I've taken off the inspection panels on the over drive, transfer case and gear box (I think). The symptoms are strange. It occurred to me in the middle of the night last week that I could do an audible diagnosis - if engaging or disengaging the OD did not change the pitch, it must be the OD right? Well interestingly enough, the pitch changes but nothing is moving. None of the gears that I can see via access panels are turning at all.. in the fact the only time I see movement is when the OD is in its neutral (b/t engaged and disengaged) and the clutch is out (and sometimes even when it is depressed).
Anyone have any ideas or education for me? What does this tell us? I dont mind continuing to disassemble things and take the OD off...but not sure what that does for me yet. Could this be a clutch issue?
Have a look for yourselves: http://www.youtube.com/watch?v=JDBZN3Qd8bo
I still cannot figure out how to use the youtube embed option on the forums... I've tried adding the URL and the video's code... any tips?
