New Keyless Entry Remote (Handset) Programming Programming for 94, 95 models (one-button models).
- Starting conditions: ignition off, doors unlocked, hood switch depressed.
- Carry out instructions 3. to 9. within 8 seconds.
- Switch ignition ON.
- Switch ignition OFF.
- Lock doors.
- Unlock doors.
- Release hood switch.
- Switch ignition OFF. If alarm is correctly accessed, horn will sound and LED will light. It is now possible to program two handsets of correct frequency to vehicle alarm ECU. This must be carried out within two minutes.
- Press and hold down button on first handset until dash LED flashes.
- Repeat instruction 10. for second handset.
- The LED will extinguish if both handsets have been programmed correctly.
Joey
97 Disco
10 MCCSm
Custom Rover Accessories
Home of the D2 horn buttons
