Which kind of jerry can do you have?
The Swiss Army mounted one jerry can inside, behind the driver- there is room there btween the bulkhead and the rear seat that is just big enough for a jerrycan mount on the passenger side this space it partially taken up withthe outside fuel filler and you can't mount one there.
There are pro and con arguments for all mounting positions, a lot of people don't like to have the cans inside.
Doesn't answer the question, but thought I'd mention I have two army style jerry can holders for sale here if anyone is in need of them.
I never used them because I too couldn't decide where they should go, but also in part because I found a British Army dual jerry can holder for Land Rovers that I purchased from Ebay UK and had shipped to FL. Can't tell you where in the Rover it would have gone because I mounted it in my m416 trailer.
At frame level inside the body. Adding a second under the seat fuel tank, doubls your fuel capacity, takes up no additional usable space (but you do loose the storage box). It does not add to the vehicle centre of gravity. its tidy and out of the way.
My 109 has 2 under seat fuel tanks plus a rear duel tank. 42 gallon fuel capacity, all at frame level, weight distributed about evenly in the vehicle, no lifting 20L cans & pouring them into the tank.
Sometimes you might want to think inside the box.
Teriann Wakeman_________
Flagstaff, AZ.
My Land Rover web site
You're right, that is something to consider. I seem to remember thinking about that for about 3 seconds and then dismissing it; for what reason I don't know. I would like to keep the under-seat storage for now, as it is the only storage I have on the Rover that is out of the weather. Until I fabricate or buy a tool chest for the back, anyway.
A 'barbie-convertible pink' 1965 88" IIA
So much woe as I have with you þoled. --Chaucer
1969 109 P-UP
As far to the rear as possible! If you have the same springs I have your ride is "vigorous". Moving it as far the the rear as you can will negate some of the effect. Yeah it reduces access from straight back but that is the beauty of a pick-up.......lean over the side. You can lay them on the side, nozzle up, in a mount, on the wheel weels and they ride a little higher but they are out of the way of the main load-space.
1960 88" SII Pliny the Elder
1997 D-90
"Fear profits man, nothing"
I thought I would comment as that first picture is of my Carawagon . I pondered on Jerry can mount locations for a long period before departing on our trip to Alaska, and when all was said and done, I decided on copying the original Carawagon jerry can mounts. Although it may look scary to some, I really dig the original look and love the set-up. If the truck was petrol I maybe wouldn't recommend it, but considering they only carry diesel, and are only ever filled for off-road, they are less of a danger than they look! Carawagon and Dormobile mounted them up front originally, as most useable space was used up for cabinets, and the original overcab roof racks were way to light to ever consider mounting a jerry can. Series Rovers have been mounting jerry cans up front since their inception. I just read about Robert Bateman touring the world in '57 in a S1 with dual jerry cans up front labelled "gin" and "tonic"! I believe those guys in "First Overland" had the same set-up as well. Obviously there can be better places for other reasons , but they've worked there for me and many other travellers in all forms of unforgiving climate and terrain for years!
