disco 1 not moveing when in gear
thanks for the response. my four wheel drive will not shift into high or low. It is stuck in neautral which makes me think this is reason why rover will not move when in drive or reverse. i am going to try lubricant this weekend or take center console out. There is a plate with rivets that gives you access to linkage on top of transfer case! do not think it is pump at this time. Thanks
- You may not post replies
- You may not edit your posts
Forum Rules
