Due to unforseen circumstances, I am going to try and sell my 1971 Mercedes Turbo Diesel IIA 88" project.
Below is a partial list of the items this includes:
New Galvanized Richards Chassis
Mercedes 5 cyl. Turbo Diesel that had approx 212K when removed. Lower pan modified to clear axle
Mercedes 240D flywheel neutrally balanced
Correct Flywheel bolts
Brand new 240D clutch Kit
Brand new slave cylinder
Fully Rebuilt NP435 Transmission
Custom NP435 Main shaft
Engine to Trans adapter plate
Series stock Transfer case
Transmission to Transfer case adapter plate
New Parabolic Springs
New Military Shackles and hardware
New Pro-Comp Shocks
Toyota FJ62 Axles with 4.11 gears
Toyota brakes
Toyota power steering box
All series body panels including radiator support, bulkhead, rear tub, top and doors.
New Brake lines
The hard work has been done. This truck needs someone who can finish it. It is currently a rolling chassis with drivetrain mounted. Not looking to part the truck, please inquire via pm if serious, I check this site several times a day. I will work on getting some pictures added. Asking $6500.
Truck is located in East Hartford, CT 06118.
Thanks
