Results 1 to 6 of 6
Thread: 1972 Series III Excellent Condition
    Default 1972 Series III Excellent Condition
    Refurbished and ready to roll
    1972 Land Rover Series III
    Vehicle ID 25900165A
    88 Wheelbase
    Marine Blue
    2.25 litre petrol engine
    Soft top (hard top included with fixtures)
    Located in Charleston, SC
    Owned since 2004
    Refurbishment completed November 2012. Mileage at completion 62,224
    Current mileage 67,217
    This Land Rover is one of the last Series trucks refurbished by East Coast Rovers before it focused solely on Defenders. “Frame off” refurbishment included new frame and stainless steel brake lines. Engine replaced with new Turner 2.25HP. Four point internal roll cage (with work light) installed and mounted to the frame for robust protection. Inertia three point seat belts mounted to the roll cage and frame. Custom Warn winch and Hella lights front bumper. The list of improvements/repairs is extensive (highlights below). Did not repaint the truck as the patina is priceless.
    Since the refurbishment was completed, the following improvements or replacements have been made:
    new shocks and parabolic leaf springs (2016)
    new Nippondenso starter motor and stainless steel exhaust system (2016)
    new fuel tank and fuel tank skid plate (2018)
    Serviced on a regular basis.
    Housed in a climate controlled garage (50% constant humidity). Only rust is superficial along seams of the axles – all the usual spots (sills, wings, seatbox, etc.) are clean. Rear tub floor and supports like new and rust free. Same with footwells. Minor corrosion holes in left front wheel well (see photo). Easy to repair.
    Excellent cold start. Hot starts on third crank. Runs perfectly. 2 wheel and 4 wheel ranges in perfect working order. Brakes work perfectly. All electricals in perfect working order. 12 volt cigarette lighter power source for your electrical devices a nice upgrade. Speedo, fuel gauge and odometer in working order (ok, the speedometer needle bounces around but approximate is sufficient at 40mph...). Clock is the only item that is not in working order - it is stuck on Solihull time.
    Refurbishment Highlights:
    New galvanized frame
    New Turner 2.25HP engine
    Rebuilt front and rear axles end to end
    Replace gear and clutch box
    Replace rear drive shaft
    Replac brake pipes with stainless steel pipes
    New firewall
    Install Mansfield heater
    Fabricated and installed 4 point safari cage (works with soft or hard top)
    New Warn 900 winch and Hella driving light custom front bumper
    New window door tops
    New window tracks (hard top)
    New locking cubby box
    New high back seats
    Some photos. More available. Asking $24,000
ID:	13645Click image for larger version.
ID:	13644Click image for larger version.
ID:	13647Click image for larger version.
ID:	13640Click image for larger version.
ID:	13641Click image for larger version.
ID:	13646Click image for larger version.
ID:	13643Click image for larger version.
    Good Morning
    2roverlabs,
    I am interested in your 88 that you have for sale. If it is still available, if possible could you send some more pics. Also a phone conversation would be great. Your write up is very good.
    This is my first time on this forum so I’am not sure this is a private message or everyone can read it. Either way works for me.
    Thanks
    BabeP38
    I sent you a Private Message
    @2roverlabs. Pls pm. Have a few questions or can call. PayPal deposit available. Thx
    Vehicle has been sold. Thanks for the interest.
    Did this truck end up selling? Thanks
