Page 54 of 70 FirstFirst ... 444525354555664 ... LastLast
Results 531 to 540 of 693
Thread: 109 NADA Registry
  1. #531
    Nov 2017
    19
    #579 is up for sale : http://www.gunsandrovers.com/showthread.php?t=9729
    Not connected to this NADA nor its owner
  2. #532
    Nov 2017
    19
    I am the owner of #808. Not much left of the original 109. I have changed the frame, the bulkhead and put in an NA 2.25 diesel. Had the truck for 20 years, will mostly get it completed when I retire...
  3. #533
    Jul 2014
    Santa Cruz CA
    232
    PIctures???
    1967 Land Rover 109
    1966 Land Rover 109
    Joshua Tyler
  4. #534
    Nov 2017
    19
    Quote Originally Posted by clearcut View Post
    PIctures???
    Here are some pics of #808. A pile of junk for most, a treasure waiting to be revealed for me... also a picture of an ad that is my inspiration for the challenge! Click image for larger version.
ID:	12511Click image for larger version.
ID:	12510Click image for larger version.
ID:	12509Click image for larger version.
  5. #535
    559159
    i will confirm with picture
    but site says i am out of room for more
    pictures how due i fix this issue?
    Working on the picture size issue for you...
    TS
    Cheers, Thompson
    Creative Director / Art Director
    Rovers North, Inc.
  6. #536
    I have 179 - fully restored and all good. only departure from original is the new disc brakes - wanted to be able to stop.Name:  winstonsmall.jpg
  7. #537
    Couple of questions:
    When I got my truck it had been sitting forever so I've done the normal things like pull the tank, radiator, etc. As I get deeper I noticed my original fuel pump is missing and there is a replacement pump sitting where the battery would normally go under the hood. There is one line coming in from the tank and one line going out to the fuel bowl/filter.
    Since my tank has been refreshed, and I have a new sender, and pick up, I figure I might as well replace the line from the back and go back to the correct pump.
    So here are my questions.
    Diameter of fuel line that I should get (3/8 or 5/16)?
    The original pump looks like it had two lines coming in and one going out. Is this correct? Where does the second line come from?
    Any help is greatly appreciated.
    Thanks
  8. #538
    Feb 2010
    Bethel, OH
    125
    The Fuel Pump should be mounted inboard starboard rail forward of the gas tank, under the floor. The Battery is mounted under the drivers seat. The original fuel pump was a dual pump.
    redbrush2@yahoo.com
  9. #539
    Quote Originally Posted by patrickfoley1 View Post
    redbrush2@yahoo.com
    Got most of the info I need.
    Still need to know if the lines are 3/8 or 5/16 and on another note were these truck negative or positive earth?
  10. #540
    Apr 2017
    BC
    17
    Quote Originally Posted by bfein1075 View Post
    Negative earth for '67 on,including the NADA 109's.
