Remove Mechanical Fuel Pump
(63 IIa 88) I installed an electric fuel pump several years ago, and now I want to remove the mechanical fuel pump, as I will never use it again.
1) Is there a block off plate that I can buy to replace the fuel pump?
2) How do you remove the fuel pump mounting plate/bracket (aka Fuel Pump Cover) that has the 6 bolts, and two studs (to mount the fuel pump) as I want to replace that gasket as well. I've removed all 6 bolts, and the mounting plate is not easily removed, and before I start trying to pry, I just want to make sure that it is removable.
Tim
63 IIA 88" (Beach with the dogs)
05 L322 (Daily)
95 RRC SWB
05 E320 (Wife)
86 930 (Rush on boost, 400HP and climbing....)
A few boring BMW's for the kids (E30, E36, E46, E53)
