Hey folks. Hoping for some light in the recent darkness that has been Disco II ownership.
Not my first rodeo with Rovers. Been in the game for about 30 years. However, my current '04 Disco II is wearing thin.
About two months ago, I started sensing I had a misfire. It began about the time I was rear ended on my way to work.
I checked the coil packs and they were not fully secured. Thinking that maybe they took a hit, I purchased new coil packs and relocated them out front. New 8mm wires.
Issue seemed to go away. For awhile. Then it returned on my honeymoon in Canada. We limped to a friends place and we ended up doing the head gaskets there. Also replaced the front O2 sensors and plugs.
Seemed good for awhile, and then on the highway on the way home, we could sense a miss or perhaps a slip. Hard to tell which. No codes.
Got home and it was rough. Definitely missing. Codes were for cylinder 1 and 6 misfire. Sure enough, not great spark on those plugs. Replaced the plugs with more 8mm plugs. Tested with a spare coil and the new coil was found to be good.
Thought that a wire on the coil plug might be suspect, so replaced the plug with a new unit.
Truck was perfect for a couple of weeks. Then, Cylinder 1 and 6 misfires back. Felt an occasional miss/slip the few days preceding the misfires today. Misfires bad enough today that I've parked the truck.
So, I'm down to two(or three) possible issues and welcome suggestions and shared wisdom.
Either I have a problem with the trigger signal to the coil from the ECU or perhaps an issues with the torque convertor/flexplate.
Cylinder 1 and 6 share one side of the coil, and I'm assuming the same trigger wire. I haven't been able to find a wiring diagram.
Love the truck. Not loving the experience currently and have nearly reached my wits end. Shopping for another daily driver as the Disco isn't dependable currently.
Thanks in advance for any feedback!
