Results 1 to 4 of 4
Thread: disk brakes
    Sep 2010
    killingworth CT
    836
    Default disk brakes
    Does anyone have any experience with Forbyn Bros. Disk brake conversion, located in california?
    Jul 2014
    Santa Cruz CA
    233
    Yes.
    I have 2 sets installed on both of my 1967 Nada 109
    They work great.
    Bud (AKA BoulderBtrett) installed both.
    We bought there shock plate for the front leaf springs. I run very large shocks. It moved angle back some distance, so the shock would not rub on part of the Forbyn brake Kit
    Blue has about 4,000 miles on its set
    Tan has about 15 miles total. Tan came home due to Bud house was in the fire zone...
    First time Bud drove Tan on the road with new brakes
    I run then on the front and rear
    josh t
    1967 Land Rover 109
    1966 Land Rover 109
    Joshua Tyler
    Sep 2010
    killingworth CT
    836
    Thanks, so you did have clearance issues with the front? I have read about Torrell, and Zues adaptation kits, this one was attractive due to the fact that I could still run 15 inch wheels. What other gear, )brake calipers) did you use?
    Cheers,
    Jul 2014
    Santa Cruz CA
    233
    I had no clearance issues, other then the procom shock issue. They are very large..
    Are host a has kit for the balance on the parts needed.
    I am not sure of the kit part number.
    I due run 16 inch tires
    josh t
    1967 Land Rover 109
    1966 Land Rover 109
    Joshua Tyler
