Engine dies at stop light. Need advice on adjustments
1963 88 NADA with Solex carburetter. Idle, acceleration and running are fine. When pulling up to stoplight and clutch in, engine wants to die. Foot or hand throttle increase keeps it running. Really would prefer not to increase the idle. Suggestions and advice? Thanks
vacuum leak !! .......... check that spring on the flapper valve atop the carb intake too.
Check the idle mixture strength is correct, may be slightly weak. If you snap the throttle open from idle then back to idle does it stall then? WS manual suggests if it does when the mixture is set correctly , the idle speed may be too low
Thanks, I'll check it out.
How do I check for a vacuum leak? Thanks
unless you have a manifold to head leak which would be harder to find just look at the hoses coming off the intake manifold and carb. removing the hoses one at a time and capping the connection at the manifold would result in a slight increase in rpm. you can also hear a leak sometimes, for the hard to find ones spray some either or something around the suspect leaking spot and you'll definitely hear the rpm jump.
i assume you have a regular 2.25 litre so there are not many places for it to leak, brake booster, vacuum advance, there just are not many places to lose vacuum. more often it's carb adj.
Hello. I adjusted the mixture screw and the idle. Not much apparent change using the mixture screw, but seems to idle better at a stop after driving, so I guess it did something to cure the problem. Workshop manual says 500 rpm idle, but I can't get under 900.
I would also like to check the timing. Timing cover is on the flywheel and looks like I need to remove it from underneath as my arms just aren't that long to reach it from the top. Any suggestions how to use a timing light as the workshop manual uses a 12v bulb. Thanks again for advice and suggestions
timing light goes to first plug closest to radiator, hook to battery as normal. timing pointer is on crank end by radiator and close to block, invisible as covered in oil and road dust? if you don't have the pointer you'll have to pull the plug above the starter as I recall though i think i've only done that once. if you can't get to 600 rpm or less something is wrong, i'd suspect the stops for that adj. on the carb itself., ( the stop isn't the adj. screw but what it screws against or something near there.
In all carbs not able to achieve low idle often means your smallest jet is plugged or restricted. You are likely running (barely) on a secondary (main) at 900rpm with your idle screw balancing act. Disassemble and clean your carb.
- You may not post replies
- You may not edit your posts
Forum Rules
