Something weird happened on the way home from work today, it was almost like the engine was losing power/clutch was slipping.
The clutch pedal felt weird too as if it was higher than normal? I pulled over to have a look to see if I was leaking fluid but I wasn't, got back in and kept going and it did it again about 5 minutes later, this time on the down shift the shifter wouldn't go into 3rd even though my foot was right to the floor! I pumped the clutch pedal and it went into gear this time mind you with a little protest. Again I stopped to check and again after a couple of minutes on the side of the road it ran perfectly for the rest of the drive.
It's a 68 Series 2a diesel.
Alan
