Window Gear Spot Welds Broke?!
  • Rineheitzgabot
    • Jun 2008
    • 386
    Has anyone ever had the spot welds fail on the arched, gear that meshes with the motor to actuate the scissor lift on the window?
    My driver-side window will not go up, so I took the door panel off yesterday. I could hear and see the motor operate, but no go on the window. I finally pushed the window back up while operating th motor, and the window went back up, but when it "bottomed out" I heard a clank, and this arched gear piece, came falling out. Upon further investigation, it appears that the spot welds broke, and it came out of alignment with the gear on the motor (then of course, it fell off eventually).
    Any suggestions?
    "I can't believe I'm sitting here, completely surrounded by no beer!" -Onslow
  • TSR53
    • Mar 2006
    • 733
    New left hand front Discovery II window regulators.
    Cheers, Thompson
    Rovers North, Inc.
    • Rineheitzgabot
      • Jun 2008
      • 386
      Thompson,
      Is there any literature on how to perform this replacement, that you know of, off the top of your head?
      Thanks,
      Gary
      • TSR53
        • Mar 2006
        • 733
        If you've already removed the door panel then...
        - Remove the protective moisture barrier, be careful it can rip easily.
        - Before you remove the window assembly, tape the window in the UP position
        - Take out your digital camera and shoot photos of the assembly installed, helpful later when re-installing
        - Installation is reverse of removal
        - Take your time, it's a labor intensive job
        - Check the window motor for brush life and use some contact cleaner on it if required
        - Waxoyl the inside of the door with the windows UP and use 120-4 clear.
        - Reinstall the door panel
        I might have missed one or two steps, but usually this process works for most vehicles. I just had to do both front door panels on my Westfalia while on vacation as the auto door locks stopped working. Grrrr.
        I'm checking with the LR RAVE manual and will see if it is of any more help.
        Cheers, Thompson
        Rovers North, Inc.
        • Rineheitzgabot
          • Jun 2008
          • 386
          Thompson,
          Sold!
          Your help is very much appreciated.
          -Gary
