Results 1 to 10 of 10
Thread: no vin number
    Jun 2008
    Fort Wayne, IN
    386
    I am assuming that you looked for the VIN on the horns of the frame. If not, check there. If you find a number, you can buy a VIN placard from Pangolin 4X4. If you do this, you can just have it stamped with the correct VIN.
    Even if you can't find the number on the frame horn, you can do what someone suggested above, and get it through records. Once you get the original VIN, then buy a VIN placard and get it stamped. This is in keeping with the spirit of honesty and originality.
    Hope this helps.
    Gary
    "I can't believe I'm sitting here, completely surrounded by no beer!" -Onslow
    Jul 2008
    83
    thanks all for the response...i was hoping for a legal way to do it ill go out right now and see if i can find it on the horn..IIRC the horns are rotted out though
    Jul 2010
    Auckland, NZ
    451
    Quote Originally Posted by BGGB View Post
    Hmmmm now there's a dilemma.
    Alan
    109 Stage 1 V8 ex-army FFR
    2005 Disco 2 HSE
    Nov 2006
    Mass.
    1,796
    Why doesn't it have a VIN plate? Be careful using the original if you can find it. Perhaps someone else is using it on a coiler "conversion". I have a plate from an 88" you could have for nostalgia purposes. Of course, what you do with it is your business.
    Jul 2010
    Auckland, NZ
    451
    Quote Originally Posted by I Leak Oil View Post
    Yeah I thought the same thing. Or it may have been written off, stolen, etc.
    Alan
    2005 Disco 2 HSE
    Oct 2010
    Galloway British Columbia Canada and Jefferson City Missouri
    269
    My 109's VIN plate is loose in the glove box as it was removed after the frame off restoration. The frame is a new Galvy so it doesn't have a VIN number on it. I am not sure that the plate in the 109 is the origional as the truck was a diesel pick up then converted to a 5 door wagon with a 2.25 gas motor which I am now replacing with a 200TDI. Should be fun when I import it to the US and go to register it.
    1968 Series IIA
    1987 D90 Kid's project
    May 2011
    Dudley, Mass.
    329
    Your chassis(VIN) number should be here on your front dumbiron: Name:  chassis_no.jpg
