Page 2 of 3 FirstFirst 123 LastLast
Results 11 to 20 of 21
Thread: Body Stability...
  1. #11
    Nov 2006
    Redding, CT
    1,504
    Quote Originally Posted by xrover
    Has a large and heavy rack on top.
    Ah ha, I always wanted one but never had one of those roof racks.
    I like the idea of adding a sway bar to it then but not sure how you could best go about it.
    Good luck.
  2. #12
    May 2007
    Ashburnham, Ma
    95
    I am tempted to take the roofrack off and forget about it all together.
    I just like the look and plan to utilize it... That should truely make it sway a bit. Just like when Fred Flintstone's car turns on it's side at the drivethru.
    Tim M.
    Ashburnham, MA
  3. #13
    May 2007
    Ashburnham, Ma
    95
    P.S. good place to get the steel wheels? RN seems to have them but, I would be open to a used pair maybe even with tires already mounted.
    Tim M.
    Ashburnham, MA
  4. #14
    Nov 2006
    Redding, CT
    1,504
    WILMAAAAA!!!!
  5. #15
    May 2007
    Ashburnham, Ma
    95
    Tim M.
    Ashburnham, MA
  6. #16
    Nov 2006
    N. York
    1,635
    Ask around on the various boards- I used to need 16" wheels pretty badly then all of a sudden I ran into a couple deals which fulfilled my needs for an eternity... Rovers Down South has them new, as does RN and all other dealers.
    Land Rover UK Forums
  7. #17
    Nov 2006
    N. York
    1,635
    I take mine off whenever I am not using it- It usually only gets used for a canoe anyway. For anything heavy I have the M416 trailer.
    People often overload roof racks and they can make a bad situation worse in a hurry. Off road they are just a menace IMHO.
  8. #18
    Oct 2006
    North MS
    981
    Quote Originally Posted by yorker
    M416
    Excellent little trailers!
    1/4 Ton, but I've had over 1/2 ton in mine.
    67 IIA 109" NADA Wagon (sold)
  9. #19
    Default M101, and roof rack
    how about both?
  10. #20
    May 2007
    Bloomfield, CT
    1,382
    Has a large and heavy rack on top. Tires are at pressure. Bushings are good.
    I think I am going to try a changing to an offset rim (wolf) and see if that does it. Any idea on the offset maximum I shouls go with?
    A wider offset won't hurt, but the body roll issue is more likely the movement between the body and the platform (i.e. springs, shocks, swaybars) and not so much the movement of the platform and the road. This assumes your tires are adequately inflated, but you say they are. The roofrack (especially loaded) will just increase the movement between body & frame
