5 Speed transmissions?
  • mongoswede
    • May 2010
    • 757
    Because of familiarity and availability my hybrid is going to start life with a 2.3 litre 16 v turbo which in stock form makes about 220 hp and about 200 ft-lbs of torque. I may change out the stock turbo to make more boost at lower rpms etc but that's not relevant right now.
    I plan on using a series transfer case and currently have stock 24 spline disco axles. Wonder what a good 5 speed to run might be. A quick search turned up the NV4500 (hd dodge 5 speed). Looked like a nice compact unit that would take anything a 4 cyl could throw at it and then might grow if I do an engine transplant later on.
    I am open to recommendations.
  • jimsshuman
    • 136
    I don't have a lot to add, mostly just curious. Is this a ford 2.3 motor? What is your project? I thought a lot about a ford 4 cyl. I think it could do quite well in an 88 inch truck.
    As far as transmission, the NV 4500 is an amazing, bullet proof, heavy duty transmission. Much sought after. I am putting one behind my 3.9 L cummins. Others put them behind several hundred horsepower (1000+), high torque motors. There is also a NV 3550 (or something similar) that comes stock on some smaller jeeps (wranglers, etc) that may work for you and be a little smaller. The 4500 is quite heavy!
    Good luck with your search and build!
    sigpic
    '91 RRC, SWB (tuned up quite nicely, new water pump, needs radiator repaired or replaced and brakes!) Sold😔
    '74 S III, diesel, 109, rhd, hard top
    (patiently awaiting cummings 4bt, nv 4500, and np200!)
    Finally IN PROGRESS!! Sold😖
    • mongoswede
      • May 2010
      • 757
      Saab 2.3 turbo. Very tractable engine that I am intimitely familiar with and can get all parts and components for cheap. I can play around with the pressure plate weight, clutch size, and turbo size to tweak the power delivery range etc.
      • o2batsea
        • 1199
        From Novak Adapters website:
        Wherever it says "Jeep" think "Land Rover"
        NV4500 Mythology
        When the NV4500 was released in the mid-nineties, the 4wd aftermarket and magazines latched on quickly. It was uncritically ballied (sic) as the silver bullet and cure-all to any 4wd powertrain problem. Phrases like "Ultimate 4wd Transmission" have been common.
        As time and trial have shaken things down, the NV4500 trend is now seen by serious 4wd powertrain aficionados as a prime example of herd instinct. Many individuals have been left unsatisfied with the expense of their transmission investment vs. its benefits. The drawbacks have been:
        Gearing:
        The NV4500 has an initially attractive overdrive gear, but with a low gear of only 5.6:1 (most units) and a gear span of 6.07, its position against the heavy-duty four speeds (SM465, T18, SM420 or NP435) is inferior. Choosing the right axle ratio and tire size in conjunction with the right transmission is a smarter strategy than using overdrive as a patch to the system.
        Size:
        The length of the transmission, even in its shortest renditions, is too long for many Jeeps, especially those with suspension lifts. The result is u-joint vibration and weakness. The transmission also often requires serious surgery of the body's tunnel to gain back ground clearance.
        Expense:
        The initial flurry to get a 4500 drove up salvage prices that have never really ratcheted back down. New units have been available ranging from $2300. - $2600. Parts availability and expense are surprisingly discouraging in addition to frequent year-to-year parts changes. Expense for NVG to build these transmissions is significant. Overdrive adds serious complications to any gearboxes design and manufacturing.
        Strength: Weaknesses in the transmission mainshaft clutch splines and their mating hubs (usually 4th & 5th gears) from fatigue and wear are prominent. The HD four-speeds exhibit consistently better strength & wear characteristics.
        Adaptability:
        Expenses and complications in adapting to either the engine or the transfer case is high. Clutch linkages also prove challenging.
        There are too many NV4500's in Jeeps due to an artificial push by aftermarket profiteers and hungry magazine writers looking for a quick story. Actual research and critical analysis by the thoughtful Jeep builder will more often yield the conclusion that a heavy-duty, four-speed transmission (if not an automatic) will produce better on-road & off-road results with significantly less expense.
        There is an Advance Adapters Series t-case to SM465 adapter
        • slorocco
          • 208
          The series t-case adapter will actually work with more than just the SM465. Matthew Jackson at Advance Adapters can tell you more specific details.
          • jimsshuman
            • 136
            That ought to be quite interesting. Look forward to reading more about this one. My daily driver is an 03 9-3 with the 2.0 T. Knock on wood, has been a great car for me, and still fun to drive!.
            As far as the NV 4500, yeah, I must admit, I'm def no expert and my only experience is from what I've heard. This makes twice, recently, that I've heard the 4500 is probably not all it's supposed to be. IDK. I guess I fell into the herd. Fortunately for me however I guess is that I got mine cheap. 1100 bills for a new, never installed unit. hopefully it will last and treat me nice if I treat it nice. Time will tell, if I ever get it on the road!!
            sigpic
            • RoverDover
              • Jan 2010
              • 144
              ask anyone who had a mid 90s dodge ram with the NV4500. A friend of my fathers has put 7 of them in his since new in 97.
              67 angry hamsters
              • mongoswede
                • May 2010
                • 757
                Thats a lot of gears
                • Boston
                  • Feb 2010
                  • 151
                  "they" always say you have to do alot of mods to a transverse engine to get it to work properly in North/South orientation.
                  • mongoswede
                    • May 2010
                    • 757
                    not so much....especialy when the engine is based on longitudonal design.
                    • distributorguy
                      • Mar 2019
                      • 14
                      I'm contemplating the same trans - the NV4500. Found a good one local for $800. The NV3500 is much more plentiful and I'm wondering if it'll hold up as well. They were used in S10's and full size Chevs with the 4.3L V6 - same bellhousing as the V8 although its integrated unlike the 4500 which can be removed. Its lighter and smaller and lighter duty, but is it enough? Rumor has it that the Advance Adapters setup fits both transmissions. Both have potential bearing noise issues over time.
