How do you hook up the horn on a IIA?
Hello...I've had no horn for monthes now, and I finally want to rectify that.
I've had a J.C. Whitney "aa-oo-gaah" type horn for years, then the horn switch went bad for whatever reason...so I hooked it up "temporarily" to a push-button switch on the dashboard.
Not good for when you want to hit the horn in a hurry!! So I want to get it back on the steering wheel switch where it belongs.
But by now, I can't remember for the life of me how the horn wires go to the center steering wheel horn switch. The horn switch itself works fine...I've tested it. And the horn itself of course works as well.
BUT how in HECK does one hook-up the wires to that steering wheel switch? I first tried hooking the positive to the switch, and needed tons of extra wire that would hang down to be taken up around the steering shaft when wheel turned. Obviously not the correct solution!!
So the negative wire must somehow be the one...does it just touch the steering colum somewhere??? and then positive from the horn just goes DIRECTLY to a positive feeder somewhere?? If the negative (ground) is hooked up to the shaft, is there enough contact for the horn to work when button depressed??
Please HELP!!
1970 Series IIA 88".,...the REAL Chitty Chitty Bang Bang.
