Results 1 to 2 of 2
Thread: Need advice on purchasing D110
    Dec 2006
    Motta Sant'anastasia Italy
    258
    Default Need advice on purchasing D110
    I am looking at buying a 1988 D110 in Italy and was looking for advice/what to look for. The engine has been replaced with a td5, the interior has been updated with that from a 2005 including AC. The owner is asking around $20k.
ID:	9262Click image for larger version.
ID:	9263Click image for larger version.
ID:	9264Click image for larger version.
    Thanks
    Stacy
    Stacy
    Motta S.A. Italy
    Jul 2010
    Boyle Heights, Ca. (L.A.)
    108
    make sure there is no RUST on the rear crossmember, bulkhead kick panel/foot wells and door bottoms. Make sure that the tranny shifts properly... make sure the transition between first and second gear is smooth. if you have trouble shifting than your synchro might be worn out and need refreshening! make sure all indicator lights work and all other electricals.... good luck!
