Page 5 of 8 FirstFirst ... 34567 ... LastLast
Results 41 to 50 of 78
Thread: Show us your 90, 110, & 130
  1. #41
    I must have been a very good boy this last year. Santa left this for me. She needs some bits and some TLC but shes a blast to drive!
    I'm thinking to finish her off with "desert storm sand" paint. First thing is to get the head gasket and hoses replaced, then figure out the heat, and do some sound proofing. The frame is in awesome shape, but currently "bare". I have been looking at options for coating the undercarriage but don't want to coat it to the point I can't get to bits and parts on the underside. Any input on this is appreciated.
  2. #42
    Dec 2009
    Dallas, Texas
    446
    Default 1961 Defender 'Imposter"
Name:	1961 Defender-Ser-IIA Hybrid.jpg
ID:	7597latest of the 61...
    Question as I've been away for a few months from this forum... I see on the host page "Military Land Rover Sales" with Defender pics and what seems order details...but no references to pricing etc. Has something changed and LR is now allowed to sell Defenders post 97 in NA ??
    thanks for any enlightenment !
    cheers, mike
    1961 Ser IIa Hybrid Defender
    1969 Ser IIa Bugeye
    1998 Disco - ex wife :-(
    2010 RR Sport Supercharged
  3. #43
    Sep 2011
    Vermont
    426
    Quote Originally Posted by mrdoiron View Post
    cheers, mike
    Defenders have not been approved for North American import since the 1997 D90, laws changed as well as EPA/DOT regulations.
    Zack Griswold
    Photos/Sales
    http://i.imgur.com/z2wLIw6.jpg - 1995 300Tdi Disco 5 Speed
  4. #44
    Dec 2009
    Dallas, Texas
    446
    yes I understand the 1997 gate, but are you saying the "laws and EPA/DOT regs have now changed" then ?
    1969 Ser IIa Bugeye
  5. #45
    Sep 2011
    Vermont
    426
    They were changed, it wasn't recently. No airbags in a Defender, airbags are legally required.
    Zack Griswold
    Photos/Sales
  6. #46
    Dec 2009
    Dallas, Texas
    446
    So they "were not changed" since the 97 restriction, is what I was saying / asking. ie: Nothing has changed it seems.
    I just got confused as to why then RN was having the "Military Land Rover Sales" link now on the main page is all - can be a little misleading. I assume this infers that 'military orgs' or related affiliations are capable of ordering Defenders in the US then ?
    thanks, mike
    1969 Ser IIa Bugeye
  7. #47
    Jan 2013
    Abroad
    5
    It all has to do with 25 year old vehicles, they are not required to meet EPA (don't know about CA though) or safety measures since they are classified as a historic/classic vehicle (hence 25 years), now if the Govt. goes back and states that all vehicles must meet the safety standards set forth in the USA for that year, then importing 25 year old vehicles might stop.. The import paperwork (emissions EPA gets signed that the vehicle is older then 25 years and it is excluded). This is what I have done for my other vehicles.
    1986 XMOD Defender 90 "Greta" 74KF25
    Originally from Cyprus, spent her entire life there until last year when she was released, I am the 2nd owner after her majesty. Pics of travels to Romania. 4500km and 11 countries, had to replace starter in Holland, oil sump gasket and rear seal in Romania.
    Work done since release:
    New HD Battery 6th April 2011
    Replace headlights and bowls 30th April 2011
    Pre MOT work 6th May 2011
    New front seats 10th May 2011
    New Front Door Seals 1st June 2011
    Fit Steering Guard 20th July 2011
    Replacement steering lock and ignition switch 20th June 2011
    Add 2 rear seats and seatbelts 2nd July 2011
    Engine Oil Change 19th July 2011
    Change windscreen upper and lower seals 10th September 2011
    Change Air Filter 6th November 2011
    Change Anti-Freeze 25th November 2011
    Replace Speedo cable (One piece) 12th December 2011
    Replace Clutch master cylinder and fluid 14th December 2011
    Paint rear tub Feb-12
    Replace door hinge bolts with Stainless steel ones Mar-12
    Replace front door locks and mechanism Jul-12
    Change fuel filter Jul-12
    Fit new door locks and striker plates Jul-12
    RAD/HAZ kit
    Cubby Box
    Radiator Muff
    Starter Nov-12
    Oil pan gasket Dec 12
    Rear main seal Dec 12
    Oil change Dec 12
    PAS Jan 13 (all new components)
    1 PAS Steering box
    2 PAS Pump
    3 PAS Crank Pulley
    4 2.5N/A PAS pump mounting bracket (replaces alternator bracket)
    5 Reservoir and Mounting bracket
    6 High pressure pipe (pump to box)
    7 Return pipe (box to res)
    8 Feed pipe (res to pump)
    9 Drive belt
    1987 XMOD Defender 110 "Berta" 32KG90
    Still getting more info on her, I am the first owner following release, picked it out from Withams.
    New parts prior to release: engine fitted (less then 5k miles), exhaust, front end, brakes, brake lines, suspension, springs, tilt and canvas, fuel tank.
    Will be adding some bits and bobs, maybe 200TDI upgrade and PAS, wolf rear seats, new front seats etc.
ID:	7643Click image for larger version.
ID:	7644Click image for larger version.
ID:	7645Click image for larger version.
ID:	7646Click image for larger version.
ID:	7647Click image for larger version.
ID:	7648Click image for larger version.
ID:	7649Click image for larger version.
    1998 Discovery II (gone but not forgotten)
  8. #48
    Jan 2013
    Abroad
    5
ID:	7652Click image for larger version.
ID:	7651Click image for larger version.
ID:	7653Click image for larger version.
ID:	7654Click image for larger version.
ID:	7655Click image for larger version.
ID:	7656Click image for larger version.
ID:	7657Click image for larger version.
  9. #49
    Jan 2013
    Abroad
    5
    Chassis and bulkhead are immaculate on both of them..Click image for larger version.
ID:	7659Click image for larger version.
ID:	7660Click image for larger version.
ID:	7661Click image for larger version.
ID:	7662Click image for larger version.
ID:	7663Click image for larger version.
ID:	7664Click image for larger version.
ID:	7665Click image for larger version.
  10. #50
    Apr 2013
    Plano, Texas
    44
    1988 Land Rover 90 - Arriving from UK on May 5th, 2013. 2.5 TD original engine, nothing more than paint, new interior facelift and mechanical repair work. AC Kit in box to be installed when she gets here. The car I have wanted since I was 16 and I have had to wait over 20 years to get. Wish they were sold here in the US. Only allowed to attach 8 Pictures so only one before picture and the rest are after restoration.
ID:	8066Click image for larger version.
ID:	8067Attachment 8068Click image for larger version.
ID:	8069Click image for larger version.
ID:	8070Click image for larger version.
ID:	8071Click image for larger version.
ID:	8072Click image for larger version.
    Nancy Astor: “Sir, if you were my husband, I would give you poison.”
    Churchill: “If I were your husband I would take it.”
