disco clock repairing tip
  • landrover77
    • Mar 2007
    • 62
    I retrieved the clock from my 1995 Discovery.
    it looks OK- connections intact etc..
    fuses look good (replaced anyway) - my ? - are there any methods to repair the clock. the issue is that it works fine until night time and then I cannot see it unless flahlight used as aid. Is there a bulb or something I missed? also-the AC switch illuminator is dim and the air recirculator switch is not illuminating - WTF! Is there any other specific fuse that I should be looking @.
    recently I had to replace the bulb that sits behind the air temp knobs and that fixed the lighting behind that area. (I expected the AC and recirculator switchs to illuminate good w/ that bulb being replaced!?
    please help w/ any personal exp. & feedback from a savvy Rover owner.
    -cheers
  • Leslie
    • 613
    -L
    '72 SIII SW 88"
    '60 SII 88" RHD
    • landrover77
      • Mar 2007
      • 62
      -thanks alot leslie you made my day!
