Top Speed on your Rover
  • Zimbos
    • Jul 2013
    • 90
    #16
ID:	16901573 no overdrive 50mph max, she starts yelling after that.i am looking for a overdive
    • stomper
      • 889
      #17
      You don't have to look too hard zimbos, new ones are being produced everyday. The difficult part is spending the coin. That, and deciding if you want a fairey or a Roamerdrive.
      • SalemRover
        • Aug 2007
        • 310
        #18
        109 SIII 5 Door soft top 235 85/r16 tires w/2.5 NA Diesel engine w/roamerdrive. The fastest I think was about 70, but I dont drive at that speed regularly, mostly when speeding up briefly as I approach an uphill stretch. The 2.5 seems to have more torque at 60 versus 55.
        • Contractor
          • Jan 2013
          • 127
          #19
          My 69' 2A with OD likes 60mph.......it will run a little faster, but I don't usually.
          I have stopped my 57' S1 @ 80mph..........I don't care how much faster it will go, it's scary.......it has a V8.
          1969 IIA - Tan
          1969 IIA - Blue
          • yorker
            • 1635
            #20
            Originally posted by Huntersdad5
            I have a 71 that at some point it got a '75 international 4 cyl and running gear. My top speed is about 45 and I'm going to check my gears this weekend to see what I have. I was just wondering what the rest of the rovers are running.
            Can you post pics of the drivetrain? From your description I assume you have the 196ci 4 cylinder from an International Scout II? You should be able to do a good deal better than 45, as your engine is more powerful than the bulk of Rover 4 cylinders out there
            4-196/4-196E
            Brake H.P. (Max) @ RPM 110.8 @ 4000
            Brake H.P. (Net) @ RPM 102.7 @ 4000
            Torque (Max) Lb. Ft. @ RPM 181 @ 2000
            Torque (Net) Lb. Ft. @ RPM 176.1 @ 2000
            vs Rover 2.25:
            LR 2.25L Petrol (3 main bearings 1958-1980, 5 main bearings 1981-1984)
            52/70 @ 4000 (KW/HP@RPM)
            163/120 @ (Torque (NM/LbFt@RPM)
            Land Rover UK Forums
            • pitchrollyaw
              • Apr 2012
              • 58
              #21
              '72 88", 2.25 petrol, Weber 34ICH and Roverdrive, 7.50x16 G90's
              Cruises very comfortably at 55 or a little over even on moderate grades, will do ~65+ top speed level, but neither it nor I are happy for long there.
              w
              '72 Series III 88 "Greenie"
              '85 90 2.5NA "Stinky"
