NAS110 not starting
When I turn the ignition key, I can hear a few relays triggering (ones right above the tunnel cover) but the engine doesn't turn over. I also noticed that there's no power to the stereo and the gauges don't respond when I turn the key to the second position, right before ingnition. I just drove the truck a couple days ago and didn't touch it since.
any help would be appriciated!!!
thanks!
Have a look at the battery terminals. If they look at all dirty remove and clean the cable ends. You will lose radio settings etc.
If that isn't the problem check the ground cable ( - ) end where it bolts to the body.
If all this is good you are most likely due for a new battery.
John
Hi John, the first thing I did was try to jump start with my classic. There seems to be something else that is wrong...some major relay or switch?? What would prevent the power from getting to the starter, gauges and radio? Note that my cabin lights are still very bright and my "door is ajar" dinging sound is still loud and clear. Primary lights and aux light still work as well...???
Frankly I'm not sure as its so hard to tell with just a description.
John
Check the 4 large fuses in the black fuse box under the hood.
