Clock Bulb
This should be a pretty simple thing...but it just annoys me. The bulb that backlights the clock has died. I have a replacement bulb but I am reluctant to pry on the clock/door lock assembly without some reassurance that nothing will disintegrate. What is the protocol?
You shouldn't have any problems replacing the bulb. All you have to do is remove the ashtray and pop out the clock (the only tricky part). You can get the bulb at an auto parts store. It shouldn't take more than 10 minutes, and I doubt you'll be able to break anything in the process unless you're considerably more reckless than me (which isn't very likely). Good luck.
