1995 D90 Wagon NAS 57/500. Green. Excellent Condition $36,000
SOLD 53k miles / 411 gears installed at 46k miles, actual mileage slightly less. Known history; Second owner, purchased form original owner whom was a collector of Land Rovers. Original paint, no accidents, garage kept. Built out for overland trekking, however, very little off-road use. Modifications and maintenance by East Coast Rover. Many additions and modifications see list...
Exterior
Old Man Emu 2” Suspension kit
Safari Guard - front bumper with brush tabs and two E.C.R. ROX recovery points with (2) - ¾” galvanized shackles
Custom stainless limb risers
Safari Guard – front and rear aluminum skid plates
E.C.R. - ROX sliders with recovery points (4) with ¾ galvanized shackles
Safari Guard - rear bumper ends
Safari Guard - rear recovery point / class 3 receiver / recovery point and ¾” galvanized shackle
E.C.R.- ROX tyrod skid plate
(6) Defender 130 rims / white epoxy coated to match roof white
(5) 33 x 13.5 Super Swamper R’s tires
Warn 9000lb front mounted winch
(Silver) aluminum wing top protectors
High output heater intake
(3) Hella 4000’s (1 pencil, 2 Euro) with OEM column auxiliary switch and stone shields
Hella rear twin bulb work light with OEM 3 way dash switch
Mantec snorkel
48” Jackall Jack, adapter, base, mount
Brown Church full length roof rack and ladder
Bilstien shocks and steering dampener
Safari Guard / Rover North - front and rear differential guards
4.11 HD front and rear gears
Extended axel vents
A.R.B. - front and rear air lockers
N.R.P. - rear stainless exhaust
Engine block heater (electric)
B. & B. - new (no use) custom easy hook tire chains (4)
Interior
O.E.M. - hand throttle
Cobra _ mounted 125 channel CB/ weather radio Model # WB 125
Custom base G.P.S. mount with Ramline adjuster base
(2) Rear jumper seats with Buckles
Badger front and jump seat covers
Defender rubber front floor mats
Level O Gauge
(2) Custom schedule 80 steel equipment bars
(2) Custom aluminum equipment / gear attach points
Miscellaneous rear tire / cargo mounted attach points
Optima battery’s (2) red top with complete marine power cut off switch
Commercial grade 5 lb mounted fire extinguisher
Recent Maintenance
Brake / clutch - fluid change 2007 @ 50 k O.E.M.
Oil / oil filter / fuel filter / coolant change 2008 @ 53 k O.E.M. (mobile one)
Water pump 2007 @ 50 k O.E.M.
Drive belts 2007 @ 50 k O.E.M.
Distributor / wire / rotor / plugs 2007 @ 50 k O.E.M.
K&N air filter 2007 @ 50 k
Front washer kit 2008 @ 53 k O.E.M.
HD winter wipers 2007 @ 50 k
Optima red top (2) 2007 @ 50 k
Waxoyl - hardwax underbody protection / lithium grease 2008. As needed
Complete Factory shop manual / vehicle manual / winch manual / misc. mannuals
Good amount of Spares included
Apologies
Button stuck on radio
Few minor dings and scratches
Some leaks (if your Rover is not leaking, your out of fluid)
Probably missing something
Not trekking
Inquiries: Joe Paolillo jp185@roadrunner.com (207) 798-0371
Photos: http://s533.photobucket.com/albums/e...aolillo_photo/
