Originally Posted by DCarr
AZRover - Did the pump work when you put it in? You mentioned in an early posting that it appeared you had no power to the pump.
Everyone - My '96 Disco died yesterday. Fuel pump fuse blown. Replaced it, it blew again. Opened up the access to the fuel pump, unplugged the wiring harness, replaced fuse, but test light shows no juice at the pump. So, I hooked everything back up, went to the fuse box and checked to see if circuit would be complete by pulling the fuse and jumping the circuit with the test light - No light, no reaction from the pump. Does this sound like a relay problem? Or is there some sort of fail safe built in that would prevent continuous power to the pump? Does anyone know where the fuel pump relay(s) are located in a '96 Discovery?
