Can anyone tell me if one needs a case spreader to install a detroit locker in a Salisburyrear end? And can anyone suggest someone good in CT that can do it? thanks Jim
I put the Detroit in my Salisbury without a spreader.
A trick used with other Dana 60 axles is to feed a wad of rag between the pinion and the ring gear as the pinion is rotated (after the hold down bolts and caps are removed) This will push the carrier out.
John
Jim,
Where did you get your Detroit Locker? Thanks.
Mine came from Rider Racing.
John
