Water in passenger footwell, Disco II
I just picked up a 2001 Disco with 100+k miles. I found the passenger footwell wet. It does not smell like coolant. I'm assuming condensation from the A/C which I have run continuously while driving these past couple days.
Any suggestions as to where to look? Is there a ventilation drain I should be looking for?
water in footwell of 03 Disco II
I also have water in the passenger footwell and took the advice on cleaning out the HVAC nipples, which were very clogged. However, that does not seem to have fixed the problem. What would be the next step without taking it in and getting fleeced by the local dealer? I pulled the center console before and it is not an easy process, and it did not really allow for access to the vents that are leaking. Should I pull the dash apart? If the dealer can "clean the lines" what do they do to do that?
