Originally Posted by Stevo
I have the Bentley Range rover manual and have looked at all the wiring schematics many times. The carpet in my rover is all pulled up and there is no headliner so all the wiring going across the ceiling is visible. I have checked/bandaged and traced backed all the wiring possible. Also I have checked the relays and replaced the fuel pump and EFI relay. Right now im not getting power to the fuel pump or the coil. Also I have noticed that on the actual ECU there is a resistor that is broken. Is there a way I can identify what the resistors on the ECU do/control so I can see what that boken one would effect?
Thanks for the links though, a lot of usefull info. I'll have to inspect that resistor you were talking about.
