95 nonstarter, but cranks
I had a similar problem, it cranked and occasionally Id get a cough of combustion. But it wouldnt fire up.
Here is what I found, I had fuel pressure so pump was ok.
Prior to the problem I had trouble maintaining idle so it deteriorated.
I ended up replacing the ignition coil (that round beer can shaped Bosch thingy for $100) which is mounted on drivers side near radiator. I also replaced the cap and rotor since they are 'wear' items. Other wear items
that can be replaced but I havent yet are wires and plugs.
Anyway that did the trick for me.
