1995 Range Rover Classic SWB
1995 Range Rover Classic Beluga Black SWB with 117,xxx miles. The truck was purchased in 2002 with 50k ish miles. The car was built up for offroading and a cross country trip that never happened. The heads, water pump and timing chain were done around 85k after a blown headgasket. For the last 10yrs the car has been serviced by Alan at Cityside. The car has tremendous sentimental value, and I would prefer it go to someone who will appreciate the truck. I'm not sure how to price it - $10k obo. The truck is located south of Boston.
Pics available here http://www.nickbellistri.com/range-rover/
2 inch Lift with Bilstein shocks (front) Ranchos in the rear
ZBar Brush bar with Superwinch (Rockware Hawse)
Rovertym Rear Bumper
Rockware Sliders
Front Skid plate
Extra set of rims
Rovertym Drop Cones
Rovertym Stainless Steel Drag link and tie Rod
Rovertym Front and Rear shock towers
Wheel Spacers
ARB Rear Air locker powered by co2 tank (not included)
GBR 4.11 diffs
GBR Upgraded Front and Rear Drive shafts
Dual Battery with Wrangler Northwest
Front and Rear diff guards
Front Skid plate
Stainless steel brake lines
E-Code head lights
Stainless exhaust
Waxoyled 3 yrs ago
Engine rebuilt 6 yrs ago with new heads, water pump, cam shaft.
The bad -
It has the usual RRC issues. It leaks, drips, and spits fluids. No worse than any other '95. It has some rust typical of any NE car of this vintage.
The drivers side door has a decent dent in it. I have sourced an extra door for replacement. It is included with the truck.
The headliner has partially fallen down in the back.
Drivers and passenger heated seats do not work
Heated wind screen doesnt work
The drivers side seat control doesnt work.
Cruise control has been removed
Transmission kick down could be adjusted - the car shifts fine through its gears, but it can be on the slow side.
