I just replaced all the seals on my 97 RR 4.6 engine. Since then I have been burning more then I should. Oil light when on with only going a 1,000 miles. Any thoughts? Thank You.
Are you burning it or leaking it?
If burning you should see your Cats clog up soon, if leaking it... I would say time to find the leak. Just because all the seals have been replaced doesn't mean one isn't leaking.
No it's not leaking. I took it back for inspection, they didn't find anything.
If your burning... valve seals or piston ring issues.
check your breather valve, also change your air filter to a high quality air filter. My son had a clogged up breather valve on his SUV, was burning oil rapidly. After fixing the problem, burning stopped, power restored.
Thank You. I don't see any gray smoke coming out of the tail pipe. I hope it's just Breather valve.
What is a breather valve?
