Just general maintenance...
Pulled the plug on the bell housing to see if there was any oil to drain (nope)
Changed the transfer case oil
Changed the gearbox oil
Greased the prop shafts
Topped up the swivel pin housings
Poked around under the truck, cleaning and trying to sort out where the drips are coming from and decided that having a garage with heat, light and music is a very good thing...
Dave
sorry this is so long.....
Quote:
Originally Posted by
SafeAirOne
Wow. Hopefully no permanent damage, though it sounds like metal-on-metal contact, so some damage must have been done. Still, sounds like you may have dodged the bullet on fatal damage!
Yeah no kidding. So like scott and others found out the spin on adapter they have is the one piece type that when mounted correctly puts the sending unit pointed more to the breakfast than the bulkhead.
My adapter is the 2 piece type, I think it gets referred to as a"pancake" type. I had it mounted so that the sending unit was pointed more to the bulkhead. Hearing the woes of others from this orientation, and not realizing that there are 2 types of spin on filter adapters, I took mine off and re-mounted it so that the sending unit is pointed more toward the radiator. Couldn't find a Fram PH8A filter at the time so I used a Puralator. Oil pressure the last 2 months with the Puralator has been fine. Oil pressure the last several years with the adapter mounted with the sending unit pointed more to the the bulkhead and using Fram PH8A filters had been fine.
So now today after replacing the seal on the right rear axle I decide to do a quick oil change. Take the Puralator filter off and put on a new PH8A. Finish the oil change and fire the truck up to see no pressure on the gauge, engine starts making a bad noise after just a moment running and so I shut it down. Put the old Puralator back on, fire the truck up again and no bad noise, oil pressure reads 40 lbs at idle.
So now I'm wondering if I should have left the adapter I have mounted so that the sending unit points more to the back of the motor and I messed up by changing the orientation. Does anybody else run the "pancake" type adapter and how is it oriented? What filters are you using? Anybody know the direction of flow of oil into the filter, does oil enter the filter or exit the filter thru the center opening on the filter?
Here's a pic of the type of adapter I have:
http://i45.tinypic.com/34gt301.jpg
Here's a pic of the adapter scott has:
http://i48.tinypic.com/2d1p6cl.jpg
Here's a pic of the rear seal replacement job, all cleaned up, brakes re-installed and ready to put it all back together.
http://i50.tinypic.com/242u0kg.jpg
