Originally Posted by
cetesse
Hi All,
For sale mechanically sound, solid frame, ready to drive.
**** Original solid frame, with original body, with original engine, with original transmission, etc… ****
Pintle Hook
Military Amp gauge
Delco Alternator
43,866 KM
Salisbury Rear-end
Includes Hard top (NOT SHOWN IN PICTURE)
I've owned her for around 3 years and put a tremendous amount of effort to bring her back to life. She was a military unit as you can see from above so the frame was wax-oiled and remains rock solid throughout.
What we've done:
9/1/09 new battery
Oct-09 new clutch slave cylinder
new starter
new ignitor
new starter relay
new tires
1/1/10 fixed fuse and got electronics to work
drained and refilled both differentials
replaced rear right reflector
replaced fuel sender and got fuel gauge to work
3/1/10 fully drained and replaced transmission and t-case fluid
replaced main shaft nut locking washer with tabs for spline nut tab washer and shim washer (37.20.25)
replaced shifter shaft, ball, hi-lo ball, numerous screws on floor
5/15/10 replaced 4 plugs and 5 wires
rebuilt fuel pump (both new manual as well as new electric pump)
7/30/10 replaced all driving and signaling lights
banged out right hand side fender
replaced fuel line from tank to manual pump
8/14/10 added electric fuel pump
8/19/10 rebuilt weber 34 ich carb
added rear mud flaps
Oct 18, 2010 replaced fuel tank and all lines
DUCELLIER distributor, added Pertronix ep-142 electronic ignition with Flame Thrower coil (40511)
replaced pump jet on carb with 76407055 (note the 55)
11/20/10 Installed Pertronix EP-142 and Flame Thrower Distributor
Installed new pump jet on Weber 34ICH carb
12/23/10 Found that 4 out of 8 valves were stuck open or closed
removed the head and had it rebuilt - new paint
5/1/11 re-installed head
BAFFLE PLATE ROCKERS 2.25 AND 2.5 PETROL - ERC9278 - £1.90 2 £3.80 5/16 INCH SPRING WASHER. - WM600051L - £0.04 2 £0.08 BOLT FOR ROCKER BRACKET 2.25 PETROL - 525500 - £0.56 1 £0.56 LOCATING BOLT ROCKER SHAFT 2.5D NA 2.5DT 2.5 PET. AND 2.25 SUFFIX C ON - ETC4460 - £1.41 2 £2.82
AIR INTAKE HOSE PETROL 2.25 LITRE AND 2.6 LITRE. - 517903 - £7.27 1 £7.27
8/24/11 Re did timing
Oil Change
Testing directionals
New heater control valve
Various new hoses
Greased the spindles
9/15/09
346999 HEATER AIR INTAKE HOSE Brand New (Genuine) 1 1.99 1.99 345624 FRONT PANEL LH Brand New (Replacement) 1 24.99 24.99 MUC4299 VENT SEAL Brand New (Replacement) 2 5.49 10.98 346346 SERIES 3 DELUXE FRONT GRILLE Brand New (Replacement) 1 18.44 18.44
10/14/11 OMESK109 OLD MAN EMU GAS SHOCKS SET OF 4 SERIES IIA & III 109" 1 $359.00 $359.00
4/1/12 4 new Champion Sparkplugs @ $2.09 each
Reset carb idle and mixture settings
4/28/12 new idle jet screw and spring "64750.048
SKU: 64750.048 $6.95 1 $6.95
5/20/12 new fan belt - Dayco 15495 (49.5") for new alternator bracket from Ike
7/1/12 Sanded down all outside panels on body & hardtop
8/1/12 new front left brake line
Make me a reasonable offer.
Shipping at buyer's choice & expense. Located in Northern Virginia outside of Leesburg.
Sincerely,
Chris
