rover overheating im at a loss
I own a 1996 4.6 hse range rover. It runs hot above 65 mph (highway speeds) and only sometimes at idle, and gets hot faster with the a/c on. i have replaced the radiator, hoses, coolant and thermostat also there are no leaks. A land rover mechanic told me the fan and clutch is good. Before I acquired the rover someone replaced the heads , water pump (it runs very smooth)installed a mechanical temp gage (when dash gage is in the red zone with the light coming on occasionally, the mechanical gage is reading around 207 degrees) and also wired the electric fans to come on when the rover ignition is switched on (runs all the time).sorry I don’t know much of its history. My question is what have I missed? I am at a loss on making this rover run cool.
