Page 1 of 2 12 LastLast
Results 1 to 10 of 14
Thread: What tool? Changing the diff oil!
    Default What tool? Changing the diff oil!
    Hello,
    Changed the tranny and OD oil this weekend. Nut on the tranny, and allen screw on the OD to drain---no problem.
    The front & rear diffs and the transfer box have a big slotted round plug. I could not remove it to drain the oil. Is there a specific tool for this, and if so what is it called??
    Regards,
    Julian
    Jun 2009
    Columbus, Ohio, USA
    740
    Is it an indented square on a round plug? If so, use a 1/2 ratchet extension with no socket attached. It'll fit in there perfectly.
    Quote Originally Posted by knac1234 View Post
    Hello,
    Regards,
    Julian
    Cornwall Ct
    343
    Use the heal of a 1/2 open-end wrench.
    Feb 2008
    East Quogue NY
    327
    This is the specific tool. I use this on my rear diff drain plug; my front diff accepts the 1/2" square drive socket.
    http://www.roversnorth.com/store/p-5706-drain-plug-tool-.aspx
    Apr 2007
    Scottsdale, Arizona
    889
    As Andrew said, I have the specific tool, only because it came with the Rover from the previous owner. a 1/2 inch wrench will slide into the groove, and then you can use a second wrench attached to the shaft of the 1/2 inch wrench to turn it with some leverage. Don't waste your money on the specific tool, and I doubt you will find one available anywhere except a Land Rover specific site. I asked around at NAPA, and other various auto supply shops, and they had never heard of such a tool.
    Default wrench
    Id say the tool is worthwhile, make your own if you can. I pretzeled a snapon 1/2 wrench trying to get one unstuck . . .
    Apr 2010
    Shoreline, WA
    408
    Google "Drag link socket", it's like a giant screwdriver bit that fits on a ratchet. (works good for removing the bungs on oil drums too)
    Gale Breitkreutz
    '03 Disco
    '74 Series III 88 (sold, 4/13)
    '47 CJ2A
    Aug 2009
    Bethlehem, PA
    400
    Default Sears
    Walker
    1968 Series IIA-"Ronnie"
    88" SW, 2.25L Petrol, LHD
    Jul 2010
    Auckland, NZ
    451
    Or replace them with 1/2" square drive plugs. Then all you will ever need is a 1/2" socket drive.
    Alan
    109 Stage 1 V8 ex-army FFR
    2005 Disco 2 HSE
    http://www.youtube.com/user/alalit
    Apr 2008
    Westborough, MA
    79
    I ground the shaft of a bolt flat so that I could turn it with a socket
