Need a harness
Know a good source for an EFI wiring harness that will fit a 91? Or for that matter what other years will fit a 91? Mine burned from the relay under the pass seat to the drivers side o2 sensor.I rewired with generic wire and replaced both o2 sensors and relays and I'm still getting a code 44. Grounds are fine. Your wisdom in this matter would be much appreciated as she only has 196,000 miles so of course I'll bandage her up again and get another 196,000. Honestly, can you think of anything better than a good running RRC? I think not!
