Ok, needing some help here guys...
I'm working on a 2.25 petrol engine with an interesting knock. I'm going to try to record a sound clip so you guys can hear. In the meantime, an explanation will have to do...
There is a knock that doesn't follow any pattern. With the valve cover off, I can hear that it's definitely coming from the valve-train...maybe the first 2 or 3 valves from front to back. I'll check clearances as soon as I can find my feeler blades.
EDIT: Nvm...file wasn't the correct type for YouTube
