I finished my wiring a few months ago and I used elevator hoistway wiring. It was already bundled with 4 white wires, 4 black wires, and a green wire. Luckily, all the wires are numbered. I ran the bundle through the frame rail then split all the white to one side, all the black to one side, and am using the green for my rear 12v accessory plug/work lamp. My wiring diagram identifies everything by numbers instead of colors so it's pretty nifty.
I used a 12 circuit (I think it was 12 anyways) fuse box that I got pretty cheap off eBay. I mounted that in the passenger dash area and pulled my front harness wires through the gauge area and the front bulkhead.
I am using standard GM type of ignition switch/key, headlight switch, and toggle switches on the dash to control everything. They were easy to find and cheap.
I used some waterproof relays that I found off of misc. 90's GM cars at the junkyard for my horn, low beams, high beams, and fogs. I also took the brackets that the relays mounted on. They are all lined up on the inside of the wing and look very clean.
I cut the rear harness off where it comes out of the frame rail under the footwell and left a few inches hanging out. I attached my new wiring to it, then pulled it through the frame rail at the rear. I used a helper to push through from end while I pulled from the other to make sure it didn't get bound up and tear or nick the insulation. Worked like a charm.
I haven't finished the turn signal wiring and I am not using a voltage stabilizer for the gauges. I removed all of my gauges except the speedo so I don't have a need for a stabilizer right now. My truck was 24v so if I ever get it running again I'll have to get some 12v fuel gauge/senders and a stabilizer.
Other than that, I don't really have any specific tips. Just plan our your diagram and make adjustments as you go. Document your new diagram for future reference. I have mine on recipe cards that I'll eventually laminate and keep in a waterproof pouch that I hope to build into the seat back.
Good luck and have fun!
J
1966 IIa - ex-MOD, ex-FFR, ex-24v
1997 Discovery SE7 - I'm empty inside without her
