Brake Pad Warning Light
Anybody had to reset the brake pads warning light? I messed up and let my front pads go too far, at least enough to set the light. Replaced the pads and the sensor, but the light is still on. Does this have to be done by the dealer? I replaced my rear pads but before the light came on. My luck this is probably like the oil change reminder.
2006 LR3
1967 109 Station Wagon
M37B1
M38A1
sensors if installed correctly shall extinguish the light, there is no reset thru scanner.
make sure they are plugged in all the way and that the hard tip nearest to the rotor is not broken.
somthing is not installed correctly thus your light being on.
- You may not post replies
- You may not edit your posts
Forum Rules
