Results 1 to 10 of 12
Thread: 1984 Defender 90 2.5 TD turbo info (not a 200/300tdi)
    Jun 2007
    Slatersville, RI - USA
    25
    Unhappy 1984 Defender 90 2.5 TD turbo info (not a 200/300tdi)
    Greetings all!
    I am looking for some help with my turbo - specifically a local resource for a rebuild kit - worst case a swap in unit.
    It is a Garrett T2 based on my research. I am told that they were used a lot here in the US in boats and cars/trucks, but only find references to them for ROW. In the US, there seems to only be T2x (x being a number) or a Dodge Shelby turbo with a T2 engine?
    Anyone have any leads for local resources for rebuild kits , swap in parts, or junkyards for sourcing alternate installs?
    All information appreciated,
    Sean
    My situation:
    http://www.youtube.com/watch?v=1BuvkGPrCu4
    - Lots o' smoke on acceleraton - exhaust blowing out near turbo (haven't pinpointed it specifically...some noted oil drips below turbo.
    - taking the exhaust pipe off this weekend and expect to find oily goo.
    Sean
    1972 Series III
    1984 Defender 90 [2.5 TD]
    1993 Range Rover
    Have you tried d-90.com? Lots of helpful members on the board. Good luck.
    May 2006
    2,020
    RN can source one for $1200.00.
    Takes about 10 days to procure.
    Let me know if this is of interest.
    Jun 2007
    25
    Quote Originally Posted by Les Parker View Post
    Thanks Les - I appreciate the offer...I'm going to pull it, have it rebuilt (if possilble). Otherwise, I am going to go the low mile 200TDI route - tho I'd rather keep it stock. Cost/benefit analsysis wins.
    Thanks,
    S
    Sean
    1972 Series III
    1993 Range Rover
    May 2006
    2,020
    Thanks for the update.
    Finding a low mileage Defender 200 Tdi is a real challenge, all the best with that. Good thing is that it is virtual straight bolt in and will throw less of its oil around the engine bay, plus you get the intercooler, plus PAS also.
    Let us know how you get on.
    All the best,
    Nov 2010
    Northfield,Vt.
    42
    Did the search on rebuilding my turbo when it was on it's way out. Found out it wasn't rebuildable due to the way it was constructed. One of the bearings journeys is the center section body itself. Once that's worn, the turbo's done. Rovers North was the best cost route for me as I had other parts coming any way.
    There are less pricey (cheap) knock off online units, BUT, gamble on if it fits or lasts.
    Feeling your pain.
    Jun 2007
    25
    Quote Originally Posted by rusty james View Post
    I think I posted it there as well as Landyzone - where there are tons of these 2.5TDs :P
    Thanks,
    S
    Sean
    1972 Series III
    1993 Range Rover
  8. #8
    Jun 2007
    25
    I got a great rebuild for about $500 at G-Pop shop http://gpopshop.com/.
    I discovered a busted lifter rod after replacing, then after checking all the valves and rods I have discovered a starter issue...
    Sean
    1972 Series III
    1993 Range Rover
  9. #9
    Nov 2010
    Northfield,Vt.
    42
    Great site. Saved it to my favorites for future use. Unfortunately, my impeller had stuck the housing.
  10. #10
    Just for the record, you can replace a trashed/worn bearing housing which will save you from having to buy a new turbo.
    Tom Rowe
    62 88 reg
    67 NADA x2
    95 D1 - R380
    95 D90 - R380
    97 D1 - ZF
Tags for this Thread
