SRS light on
Recently my SRS light came on my 99 Rangie -somtimes it pulsates or just stays solid.I tried to discoonnect battery but no luck.Is there any way I can take off myself without taking to dealeship? Is it an important message? I am told but others that its just an "idiot" light?Should I be concerned?
You will need a shop with one of the specialist Land Rover test tools to find out why the light is on, and if possible, to clear it. If there is no suitably equipped independent near you, the dealer is the only option.
I suggest you avoid battery disconnection as it will simply record more faults and send service personnel down false trails at your expense.
