Anyone know the torque specs for the large bolts that hold the series bellhousing to the tranny? Had to swap out the 6cyl bellhousing for a 4cyl one and need to re assemble everything.
Tight.
Land Rover didn't provide torque specs for them.
I'd measure them and torque accordingly.
Tom Rowe
Four wheel drive allows you to get stuck
in places even more inaccessible.
62 88 reg
67 NADA x2
74 Air Portable - The Antichrist (tag 6A666)
95 D1 - R380
95 D90 - R380
97 D1 - ZF
Thanks. I won't waste any more time looking. Good and tight will do.
Just use the standard torque specified for that size/thread pitch bolt:
http://www.engineershandbook.com/Tables/torque.htm
EDIT: Sorry it's probably Whitworth if it's on the transmission, right? Here's that chart:
http://www.engineershandbook.com/Tables/torque4.htm
--Mark
Never even though about that. Good idea! Thanks.
Mark,
Yeah, that's what I meant by "torque appropriately."
Tom Rowe
62 88 reg
67 NADA x2
95 D1 - R380
95 D90 - R380
97 D1 - ZF
Those torque numbers are for the bolts. If the bolts are going into aluminum alloy castings, then the castings strip before the bolts do. Just go with goodandtight.
