Started a new thread as I have a new focus on my potential transmission swap from a SIII into my SIIa.
Can I keep my SIIa bellhousing and just swap the actual transmission from the SIIIa if both are 4 cylinder engines? Trying to mitigate the issue of the clutch actuation method (which are different between the SIII and SIIa)
Are the input shafts and bellhousing mounts are compatible between SIII and SIIa's (both 4 cylinders)?
Derek
