Originally Posted by
o2batsea
Alternately, you might consider putting pre ABS Discovery 1 or Range Rover axles under it. These come with discs front and rear, are fully compatible with the Series drive shafts, have a taller gear for better highway driving, and are easy to get parts for. For about what you'll spend on new Series brake parts you'll get both front and rear from your friendly Used parts guy and probably have change left over. They're much better axles hub to hub and the series wheels will bolt right up. Other than being a tad wider than the series axles you'd never be able to tell outwardly. Cutting off the coil spring perches and fitting leaf spring perches is a simple, tried and true and well documented Rover conversion. My $.02.
Oh and you might also consider Parabolic springs with military shackles. Gets the thing up in the air a bit more.
